Blindasabat
I have just about settled on the Novatac/Ra being my favorite UI ever. I would like to see a slightly smaller Ra (namely thinner so I can EDC it in office wear pockets with a deep carry bezel down clip), but that does not seem likely to appear so I have started to wonder if I can transplant a NT 120P or Ra driver into a host like a Peak Rainier or something of that size with a similar silent momentary switch.
The EX10 is close to perfect UI too (and a better size) but needs head twisting to go from momentary to constant on, while the HDS UI is still the best way for me. I have my HDS & NT set up with simple momentary enabled and think it is the best idea since the wheel.
One problem I see is making the driver work in a new host since it uses multi-contact with a seperate signal path to operate.
Solution: use a floating battery and an Arc/FireFly2 switch at the head to signal. There is a name for that type switch, but I can not recall it right now.
I don't know the diameter of the driver - does anybody? It may not fit in anything smaller diameter than the Ra 0.95" (24.1mm), but I'll have to find that out. If it can't fit in anything smaller, then I may just mod a NT head onto a thinner body. A body with a small raised ring about 50mm from the tail for cigar grip activation. Less of the length at 24mm the better for me.
Any other problems with transplanting the NT driver into an alternate host I'm not seeing? I've never seen it done before, so I wonder why not?
I have been thinking about a light like this for a long time and may have found a concept worth spending a few hundy making it happen.
The basics
* XP-E & XP-G swappable PILs (throw & flood options)
* Ledil Tina XP-E 7deg or LXP 5.5deg optics
* Slim steel bezel ring like the EX10
* Peak brass momentary switch to push the battery forward (silent!) or maybe the EX10 style piston.
* RCR123 with possible 14500/17500 body option/extender
* Not more than ~95mm long
* Aluminum body with grip features - I'll get it Ceracoated or H-Ano'd
* EX10, VG, or other bezel down clip - preferably AiTN? (black) coated
There, I just had to write that all down.
The basics
