Hi Bernhard...
I have two Pelican M6`s that I`ve outfitted with the Flashlightlens clickie conversion kits. If you have some basic tools, like a screwdriver and an adjustable wrench, you`ll be able to do the job.
The part of the project that is a real PITA is seating the new clickie unit into the PM6 tail. You have to use brute force to do it, as far as I know from my own experience.
What I did, though, was to find one of those plastic conical-shaped wire nuts (that you use to attach two wire together), and placed the open end of the wire nut against the open back of the new clickie unit that had to go into the tail. (You need to use the "right size" wire nut so that it fits into the interior of the clickie unit, but without resting on the kroll switch parts.)
Once I did this, I then took a large adjustable "channel lock" type of wrench and put the wire nut/clickie unit/tail combination between the the jaws of the wrench, and forced the clickie unit to the bottom of the tail unit.
It was a little unnerving if, like me, you like to have tolerances where parts simply and easily slide together. This "truck mechanic" approach, though, did the job.
It`s well worth the effort, by the way. I`m not a big fan of the PM6, because I`m spoiled with the high quality machining of the Surefires and the Arcs. The PM6 is, IMHO, several notches below those flashlights in that regard. The PM6 makes up for this deficiency, though, with its low price. It`s a matter of "You get what you pay for."
Notwithstanding my reservations about the quality of the PM6, I bought two of them to host the McModules that Charlie and Don have made and/or are creating for it. I see that`s why you bought a PM6 as well. ("Two birds of a feather"...? /ubbthreads/images/graemlins/help.gif /ubbthreads/images/graemlins/grin.gif)
Back on track, the clickie conversion works well, and is a great improvement over the original PM6 tail switch. Go ahead and try it. (Or, of course, you can also apparently just buy a Surefire Z48/Z49 tail and put it on if you don`t want to mess around with any of this.)
In fairness to the fine folks at Pelican, I will be the first to admit that the PM6 is a great light for the price. I just wish it was of a higher quality, however, so that one would take it out and admire it just for its fine craftsmanship. When I look at my PM6`s, though, I instead just see how great it "could" be. Oh well...so much for my rather unfair and totally gratuitious grousing about the PM6. It`s a good flashlight!
Best wishes to you, Bernhard!
/ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/smile.gif
