A question about IR filters
Sniped222
I am very new to this forum and apologies in advance if this thread is in the wrong section
Just have a problem that i think you guys should be able to help me with!
I have been looking for a Infrared filter for my Fenix LD10 (bezel size 22MM) at about 850NM
does anyone know of a filter that would fit properly, the smallest i could find was 1" bezel size filters which are about 25MM. would this work?
I am on a budget (£40 ish absolute tops) so cheap = good
Thank you very much!
Echo63
Perth - West Australia
Its an LED flashlight so it produces very little IR light to begin with.
even if you do find a infrared filter that will fit it wont work, you need to either mod your existing light with and IR led, or buy a new Light with an infrared led.
Incandescent lights produce lots of IR (the heat you can feel if you hold your hand in front of a nice bright incan) so the filter does work for Incandescent light
John_Galt
SW, PA
Buy an oncandescent light. LED's produce very little IR, and what little they do produce, probably isn't in the 850Nm range.
Or you could buy another LED light, and swap in an IR LED in that spectrum, and replace the lights LED with it.
Moonshadow
Scotland
:welcome:
I use a Solarforce L2M with an IR drop-in, which should work out at around your $40 price point.
What are you planning to use it for ?
Sniped222
:welcome:
It is for use with night vision in a Forrest and out on the moors although i don't think i will need it too much on the moors
Thanks for all advice, can anyone recommend a ir light that i could buy
Thanks for all advice, you saved me wasting my money
