Hi guys. I built a nice incan light with the following parts:
- Solarforce L2M
- bunch of solarforce and lumensfactory extensions
- z41 tailcap
- FM G4 sunlight D26 bipin socket
- WA1185
- 3x18500
I scoured the forum on what battery combination and what tailcap/switch would be able to feed an 1185 without failing or being at very high risk for instaflash. I came to the conclusion that with this setup, I'd be at some risk for instaflash, but the switch would be fine.
I was checking the light because the contact at the drop-in was intermittent (solarforce socket is a bit too big for the G4 dropin), and I found that the drop-in's spring was discolored and collapsed. Hmmm. So I checked the tailcap as well, a stock Surefire Z41, and sure enough, that spring was also deformed.
So I need your help.
1. Is it normal for a FM G4 sunlight's spring to deform with 1185? I have a feeling not.... Similar question for Z41.
2. Where can I get replacement springs, for the dropin and the Z41? Perhaps upgrade springs that can handle more heat/amperage.
3. Would a spring mod (solder decent gauge copper wire at either end of the spring) help avoid the spring meltdown, at the price of increasing instaflash risk?
Pics!
Thanks!
- Solarforce L2M
- z41 tailcap
- WA1185
- 3x18500
Pics!
Thanks!
