Originally posted by Brin:
....The thing is when I have to run out of the car to chase someone or something like that I most often do not have time to grab the large mag light and often need to rely on my belt light.... These are situations where I need a low weight and powerful light.....
My thougts now: I think that the stinger is a bit large for a 12 hour day belt light.
So I have to deside between the scorpion, 6p,e2,and g2.
Anyone know witch is the brightest of these?
<font size="2" face="Verdana, Arial">Brin,
When I first read your post about the 2AA MAG, I couldn't believe you were serious; I thought it was a joke, sort of like using a horse drawn cart as a patrol car.
Based on my experience with these lights I would exclude the E2 from your list. When it first came out it had a very diffuse beam, which although later improved by a redesigned reflector, is still is no match for the other three lights you mentioned. If you need a "serious" pursuit light then it's critical to focus on the brightest 2x123 lights available.
The 6P and G2 take the same Surefire lamps and are essentially the same except for the 6P's metal body and the G2's composite body with metal tube insert. The 6P comes with a "lock-out" tailcap, and other CPF members can confirm whether the G2 has this feature. I prefer the G2 for two reasons: It's lighter and the composite body is warmer and easier to hold onto in cold weather.
Even as a relatively unemcumbered civilian I've found that an ounce or two less on my belt makes a difference, and I think that any weight saved on an officer's heavy duty belt is worthwhile. Here are the weights of the three lights under consideration and a fourth, the Asp Taclite, which I feel is worthy of inclusion despite its weight.
All weights include batteries weighed on a digital postal scale accurate to 0.1oz
Taclite: 5.4oz
6P: 5.3oz
Scorpion: 4.6oz
G2: 4oz
The Scorpion is an excellent value and may be slightly brighter than the two Surefires in the first few minutes of its burn. There are four reasons why I do not carry the Scorpion and why I don't think it is ideal for critical use:
1) In a dynamic or chase situation when you may need to present the light immediately in perfect focus for optimum intensity, an external focus light that changes focus as easily as the Scorpion can put you at a disadvantage
2) Battery change can only be accomplished by removing the head and destroying focus. After reloading you will have to focus once again, so that even if you achieved optimum focus and taped the head in place you would still lose valuable, perhaps critical time.
3) At tightest focus its hotspot diameter is slightly larger than the Surefires, and as the batteries begin to fade, the Surefire's tighter beam becomes an advantage
4) Its recessed tailswitch is very sensitive and can easily be accidently activated.
If you need a very penetrating super bright small light, then I would recommend the INTERNAL FOCUSING version of the ASP TACLITE with TRIAD lamp as one of the two brightest, longest throw 2x123 lights currently available. The only other light in its class is the TACM III which is also a super bright 2x123. It is an excellent light, but of somewhat less robust and detailed construction than the Taclite. It is, however, fully waterproof.
If you are interested in the Taclite, you should know that it has a "clickie" switch. Click on/ click off. No momentary on. I personally prefer the Surefire "push button/ turn to lock" system even though many in our group like the clickies. One of our senior law enforcement professionals still prefers his Taclite to other lights, but that is a minority opinion.
Here is some discussion about the Taclite in case you're interested:
ASP TACLITE THREADS AND INFORMATION
Good luck,
Brightnorm
