js
\"SureFire L4 only a toy\"-RETRACTED! My apologies
See my apology below! Sorry everyone for being so hot-headed
Well, another edit. See new thread "IS the L4 too hot to hold?"
Below is my original post, which no longer applies, as I
was working from incorrect information from a previous
thread "L4 Liquid cooling?" or something like that. My
appologies to all you L4 owners, and thanks for setting me
straight.
Sorry to have to throw down the gauntlet on this one, but
after reading about the heating issue of the L4, I can't
help but come to the conclusion that it's only a toy and
not a serious flashlight or a good EDC and thus only useful
as a novelty item.
OK. I will grant that it is very well made and bright
at a constant level and that the light it gives is a nice
color, and of course LEDs don't break or need replacing.
BUT it seems to me that only being able to use a light for
20 to 30 minutes is a SERIOUS drawback in an EDC. What
happens in those situations where you need it for longer?
And if you can't think of any such situation that's likely
to happen to you then you probably don't have any business
owning a $150 EDC flashlight. For that money give me a D3
or an M3 anyday, assuming that you actually NEED that much
brightness and if not, give me an Arc LS or AAA.
I mean, if it's just a situation where you like to sleep
with your flashlight by your pilow and admire it and shine
it up at the ceiling every now and then. or where you like
to impress passersby with your HIGH TECH LED light, then
yeah OK, go ahead and waste your money on a poorly designed
and impractical light. But if, like me, you actually NEED
a flashlight and also appreciate having an EDC, then the
Arc LS or SureFire E2 is for you.
If I'm all wrong here, then will someone PLEASE explain it
to me? WHAT is the deal with an EDC that can only be used
for 20-30 minutes? Do all of you L4 owners just fail to
imagine a situation where you will need it for that long?
Personally, even aside from my work, I can think of half a
dozen scenarious. Not very likely, to be sure, but far from
impossible.
Wait! I have it! Just carry a Nalgene bottle full of water
with you where ever you go!
straight.
as a novelty item.
impossible.
