Can Surefire G2 LED feed on 2xRCR123 or similar?
Status
Not open for further replies.
csshih
San Jose, CA
yes it can.
both 17670s, and r123As (assuming you're using the P60L)
the P60L can take up to 9V iirc.
SimpleIsGood229
csshih has got it. Assuming you have the stock LED module in there, it's fine to run on 2x RCR123. Surefire may not condone it, but you'll be fine.
kramer5150
Palo Alto, CA
Just to further elaborate....
The P60L is standard in the 9PL (3xCR123). So its designed to handle 9V. Its perfectly stable with 8.4V
Kestrel
Willamette Valley, OR
Running 'search' utilizing the keywords 'G2LED 2xRCR123' yields the following threads in the first page alone:
help with G2 led upgrade - Page 2 - CandlePowerForums
Page 2-help with G2 led upgrade General Flashlight Discussion. ... In a G2 I'd recommend 2x123 primaries or 2xrcr123's for a rechargeable setup. ...
Surefire 6PLED With Recharchables? - CandlePowerForums
13 posts - 7 authors - Last post: Mar 3, 2009
I use a 17670 in my G2 LED, and am very pleased with its performance. ..... I can't understand why 2xRCR123 is so popular in this ...
max runtime min $ - CandlePowerForums
12 posts - 10 authors - Last post: Feb 28, 2009
I've been looking at the surefire G2 LED, which is at the top of the .... it runs off 1x18650/17670, 1x16340, 2xCR123, 2xRCR123, 2x18650. ...
Surefire G2 throw question? - CandlePowerForums
20 posts - 13 authors - Last post: Oct 22, 2009
Surefire sells the G2 LED which has a metal head and is good for ..... This will give you FAR more useful runtime than 2xRCR123 LiIons. ...
RCR's in SF E2DL & E1B - Page 3 - CandlePowerForums14 posts - 11 authors - Last post: Apr 10
G2LED, 6PLED, Z2LED, C2LED, G2ZLED, Or any 2xCR123 size unit utilizing a .... E2L/KX2 runs great with 2xRCR123 cells. It uses a buck driver. ...
DM51
Borg cube #51
Kestrel has given links to other useful threads on this topic, so this thread is no longer required and is therefore closed.
Status
