My visual background, 20/17 vision however I have 'contrast' color blindness - means that as things have more white or black in them I have a harder time telling the difference in the colors. So take what I say with a grain of salt on the beam.
Got the TK20 after a lot of reading and waiting to make sure that it was the right light. My purpose was for the BoB (Bug Out Bag) as a beefier light to go along with the Quark Mini AA I have in there now. The Quark is nice but I treat it like a delicate candle that i don't want to ruin. Since I built off of Eneloops + Solar Charger, going with AA was the right call.
TK20 came in from 4Sevens very quickly and with no issues at a great price. Yellow handled version.
Physical impressions were very positive. Beefy, great clip, feels like it can take a serious pounding, easy interface, nice sheath, etc.
Basically I was finding that everything I heard/read about the light was 100% accurate.
I took the light out tonight for the same 4 mile walk I always do. Lots of streetlamps around with pitch black areas inbetween. Hills and ditches over 400 yards in length in some spots to light up.
The beam unfortunately fell flat for me.
First off, I was not used to a warm LED. Even though I realize that the perceived lumens will be lower, to my eyes, the LED made things fairly hard to see at range. Even though the light got there, it made things less distinct. Maybe it is my eyes only but it took over half of the walk to get used to it.
The beam profile confuses me. It is very tight. Much like a Rebel Maglite in profile. In fact I compared the 2 side by side and they are almost identical. I know this is to incresae the throw however it was not putting out enough light in low or high modes to really take advantage of it IMO. Keep in mind that the streetlamps are near'ish (usually within 100 yards or so) and putting out the same 'kind' of light, could be there is some saturation which is unfairly compromising the beam.
This tight hot spot also made up close work poor. The spill ended up being really nice in that 5' - 20' range however the hotspot became distracting due to it being so much brighter and distinct.
I tried to 'not' compare the TK20 to my E2DL however it was hard not to (although unfair).
Comparing it in throw to the E2DL you notice that the hotspot is half as big on the TK20. I think this is where is really fell flat. Since it does not have the lumens to back it up, I think they should have made it a <100 yard light and increased the hotspot in diameter. Unless you know what you are looking for or if you already found it, using the light to search would be annoying. Unlike the E2DL which has a nicely sized hotspot which allows for you to search more effectively.
So I tried comparing it to my D10.
The D10 was overall a better light to my eyes. It is not a warm version (one of the older variable models).
Up close the D10 has a much better spill/blend where it is nicer to use in that <20 yard mark.
Another note on the light is that the inductor whine on high is very noticable. The whine it puts out is clearly audible from a few feet away and up close in hand it gets annoying although it is something you would get used to over time.
As for the TK20 beam I think the best fix would be to double (at least) the size of the hotspot and give up on the advertised 150 yards that it is supposed to throw to. Even if the light reaches that far, it is not useable to my eyes at least. This would also fix the up close issue where the beam is just too segmented to really make it useful up close.
To be fair, I am seeing the value of the warm LEDs but only indoors so far. Comparing it to the D10 in a room full of pictures you can clearly see that the warm LED shows colors far more naturally. Outdoors though it does not work well for me and my eyes (so far at least).
The light will not go to waste, the plan is to give it to my father in law who will love it. It really is too bad though, I honestly like everything about it except the beam profile and the aubile whine it makes in high.
