guncollector
Greetings everyone,
Recently our esteemed forum owner, DavidW, sent me 2 Xenon bulbs in a cardboard/blister pack labelled Dorcy XPR-103. These bulbs were sent for a head-to-head comparison against the Carley Lamps Xenon Star #713 (XS #713). The Dorcy bulbs are marketed through the national Sears chain of department stores--and possibly other outlets.
Both of the above-mentioned Xenon bulbs are designed for use in 3-D Cell powered flashlight units, i.e. Maglite 3D amongst others.
The following are pictures of the two bulbs in a side-by-side comparison beamshot format. Both were emplaced in identical Maglite 3D units, and pictures of the beams on tight focus were taken--one with the regular lens, and one with WrightRight (made for PDA's) diffusers applied to the lenses. (Note: for testing purposes, and to avoid skewing the results, I actually swapped out and tested the different maker's bulbs in the two different Maglite 3D units and could find no discernable difference in their respective beams resultant from the switch.)
Here's the first pic with the standard lens installed:
What is not as noticeable from the pictures, but more so to an eye-witness, is the whiter and slightly brighter light from the Carley XS #713. (Note: DavidW shipped 2 Dorcy XPR-103's to me, and the Carley XS#713's were whiter than either Dorcy when installed and compared side-by-side).
But, without any diffuser installed, notice the "batwing" beam distortion from the Carley Xenon Star #713. I believe this is a function of the elongated and cylindrical-shape of the XS #713's bulb. As DavidW indicated, Dorcy (Sears) XPR-103 bulb has a better beam shape--with stock lens--due probably to its more "squat and barrel"-shaped configuration.
(Note: Carley Lamps has available special mini-washers that assists in "centering" the bulb in your particular reflector. Once "centered", the batwing distortion effect is greatly reduced as to be almost negligible.)
Next, see the following photo of the beams with diffuser applique on the Maglite's lens:
Notice that with the WrightRight diffuser applique in place, the "batwing" distortion of the XS #713 disappears, and even the XPR-103's beam shape is improved a bit.
Conclusion: The Dorcy XPR-103 is a fine alternative to the Carley Xenon Star #713. In fact, if you're not going to apply a diffuser to your lens (or don't have the Carley mini-washers to assist in "centering" the XS #713), I would say the XPR-103 is an outright winner due to its "drop-in" beam shape (despite being a touch less bright and less white than the XS #713).
However, if you're going to apply a WrightRight-type film diffuser to the lens of your flashlight unit, have the Carley mini-washers, or alternatively have a stipled reflector, then I would recommend the Carley XS #713--for its slightly brighter and whiter beam.
Either aftermarket bulb is a great improvement of the standard Maglite Krypton bulb.
Next, I'll try and get comparison shots of the XPR-103, XS #713, and the newly-released Maglite Xenon bulbs (when I can get my hot little hands on one...anybody have a spare then can send to me for testing?).
HTH.
HTH.
