geepondy
OK a friend of mine is travelling to Australia and I giving her my AT&T calling to take with her. Tonight I called customer service to get the details on how to use the card to call from Australia to the US and although I got the gist of what to do, her accent was so heavy and it took so long to get the general details, I didn't ask for finer points. Wonder if anybody has actually done this. OK, she said there are two carriers in Austrailia, Optus and Telstra. You must identify which carrier you are using and then number depending on the carrier, dial a 1-800 number that is similar to US only three last digits, not four. Then you dial the 1-800 number on the calling card, minus the one. Sounds simple but questions?
1. How do you identify the carrier?
2. Is there anything you have to do first before dialing the carrier 1-800 number?
3. After dialing the carrier 1-800 number do you immediately dial the card 1-800 number minus the 1 or do you wait for further instructions before dialing that number?
4. After dialing the card 800 number I assume you then proceed as if in the US making a state to state call?
5. Am I missing anything?
The reason I am trying to get all the details is that the person I'm giving this to is very nervous about the whole thing and I want to try to get the exact procedure so she won't be thrown any curve balls when attempting to use it.
A diverse subject I know but the diverse knowledge in this forum is amazing.
