Well, I'm sure you're all dying to know how I did this (or else just want it to stop showing up bold in the list of threads) so I will get right to the point. Here is how you do it.
1. Take the clip off of the Arc AAA, then put it back on backwards.
2. Position it so that the tip of the clip (the end that doesnt attatch to the arc) is even with the head.
3. The turn the light on.
4. Slowy turn it towards the off position, but as soon as it goes off, stop.
5. Press down on the clip. Release for the light to stop.
It should look like this.
If it does not work, you may need to repeat step 4. Otherwise, you may just be out of luck. It does not work will all of my arc aaa's. Maybe it would help just clean the contacts and re-grease it.
Just one more reason why Arc is better than the competition! /ubbthreads/images/graemlins/grin.gif
