I just got a Turnigy Accucell-6 based on recommendations from this site. I like it and appreciate the information provided here.
I was charging some new Eneloop AAs and monitored temperature with a probe from my multi-meter. These particular cells terminated 1300mA charging on delta V with a temperature of 38C. Occasionally, it would miss the termination voltage and temps would steadily increase. I manually stopped charging at 45C.
At this point, I decided that I would like to have the ability to terminate based on temperature as a backup to delta V. I had a hard time finding the info needed to make a sensor although it's gotta be on here somewhere. I finally found this:
http://turnigy.co.uk/accucell-6.html
It was stupid simple to make and the parts total was $2.28 (I had wire and heat shrink on hand). The Digi-Key part numbers I used are LM35DZ-ND for the sensor and 3M9514-ND for the connector.
The connector doesn't have the extra material to insure correct alignment. I ran out of patience trying to find one. This one can be installed up side down. Doesn't hurt anything, but doesn't work, either. I put some paint marker on it to note proper alignment. Anyway, it works fine and terminates just like it's supposed to. Maybe someone will post a part number for the "proper" connector.
