Re: Nice shiny silver Arc AAA.
toneloe... Yes, the teal looking one is actually a blue CPF member body. Im not sure why it turned out so teal in my pic. The flash lightened it up.
zorba... It is a LYE solution. You can buy powder lye, that is used to unclog drain pipes. You mix it with some cold water in a container, and submerge the piece in it. The LYE will eat the HA right off of it. You let it soak for a few minutes, then tkae it out and whip it down, getting off all the HA that will come off. Then place it back in the solution, and repeat the process as needed.
tsg68... I dont know if you should use liquid draino. It has other chemicals in it that could discolor the Aluminum. Plus, there might not be enough LYE in it to do the trick.
I used this Red Devel LYE powder.
WARNING - - - LYE will eat skin! Not as well as it will eat HA, but still. Don't do this bare handed like I did. Plus, do this in an open area, with good ventilation. The fumes are killer. - Yes LYE will pit the aluminum if you leave it in too long. Thats why you have to keep an eye on it, and keep whipping it down. -- Also.. try to swirl the container as the piece soaks, so it doesnt make a mark where it was sitting on the botton of the container. You can try to tie something to the piece, and suspend it in the solution, but i found this not really needed.
