HDS Systems
Results 1 to 4 of 4
Thread: McFlood & Lens questions from a newbie
    Feb 2003
    Quebec, Canada
    Default McFlood & Lens questions from a newbie
    I own only 2 lights: Ultra-G and InRetech 2AA. I am about to buy a bb400.
    - How wide is the McFlood beam compared to an Ultra-G?
    - About the mineral glass lens: does this work with the Inretech 2AA also? The instructions tell to remove the lens and replace it with the optic, which looks like a NX05 to me. I'm a bit confused here, do I need a lens with my Inretech? [img]/ubbthreads/images/graemlins/help.gif[/img]
    Oct 2001
    Louisiana, USA, Earth
    Default Re: McFlood & Lens questions from a newbie
    Here is a McFlood.
    And an Ultra.
    This might not be the best comparison but it will give you an idea of the difference.
    Flashaholic* shankus's Avatar
    Feb 2003
    Mojave, CA
    The lens should work with any modded mini-Mag or Brinkmann Legend.
    I've not seen an Inretech adaptor yet, though.
    The way it works with MadMaxes & BadBoys, is the lens goes into the head, then an O-ring, then the colimator. You then screw the head into the lens retaining collar.
    Flashaholic* tylerdurden's Avatar
    Jan 2003
    Roaming Around - Southern USA
    If you buy a turnkey light from Inretech, it ships with the optic installed without a lens in front, much like the arc. It works just fine like this. If you back the head off a bit, you'll see there is enough space there to slip a mineral glass lens in, though. You can do it either way.
