If you haven't run Windows update for more than a month and are not behind a good firewall, it's worth downloading and installing the following security patch from microsoft.
XP Patch
This will guard against the rather nasty MSBLAST worm thats very widespread at the moment.
If you are infected the symptom is the following message:
Followed by a forced shutdown.
PS. This does not relate to 95/98 only XP NT and 2000
If anyone wants the full techie rundown, here's the CERT advisory:
> CERT Advisory CA-2003-19 Exploitation of Vulnerabilities in Microsoft
> RPC Interface
> Original issue date: July 31, 2003
> Last revised: -
> Source: CERT/CC
> A complete revision history is at the end of this file.
> Systems Affected
> * Microsoft Windows NT 4.0
> * Microsoft Windows NT 4.0 Terminal Services Edition
> * Microsoft Windows 2000
> * Microsoft Windows XP
> * Microsoft Windows Server 2003
> Overview
> The CERT/CC is receiving reports of widespread scanning and
> exploitation of two recently discovered vulnerabilities in Microsoft
> Remote Procedure Call (RPC) Interface.
> I. Description
> Reports to the CERT/CC indicate that intruders are actively scanning
> for and exploiting a vulnerability in Microsoft's DCOM RPC interface
> as described in VU#568148 and CA-2003-16. Multiple exploits for this
> vulnerability have been publicly released, and there is active
> development of improved and automated exploit tools for this
> vulnerability. Known exploits target TCP port 135 and create a
> privileged backdoor command shell on successfully compromised hosts.
> Some versions of the exploit use TCP port 4444 for the backdoor, and
> other versions use a TCP port number specified by the intruder at
> run-time. We have also received reports of scanning activity for
> common backdoor ports such as 4444/TCP. In some cases, due to the RPC
> service terminating, a compromised system may reboot after the
> backdoor is accessed by an intruder.
> There appears to be a separate denial-of-service vulnerability in
> Microsoft's RPC interface that is also being targeted. Based on
> current information, we believe this vulnerability is separate and
> independent from the RPC vulnerability addressed in MS03-026. The
> CERT/CC is tracking this additional vulnerability as VU#326746 and is
> continuing to work to understand the issue and mitigation strategies.
> Exploit code for this vulnerability has been publicly released and
> also targets TCP port 135.
> In both of the attacks described above, a TCP session to port 135 is
> used to execute the attack. However, access to TCP ports 139 and 445
> may also provide attack vectors and should be considered when applying
> II. Impact
> A remote attacker could exploit these vulnerabilities to execute
> arbitrary code with Local System privileges or to cause a denial of
> service condition.
> III. Solutions
> Apply patches
> All users are encouraged to apply the patches referred to in Microsoft
> Security Bulletin MS03-026 as soon as possible in order to mitigate
> the vulnerability described in VU#568148. These patches are also
> available via Microsoft's Windows Update service.
> Systems running Windows 2000 may still be vulnerable to at least a
> denial of service attack via VU#326746 if their DCOM RPC service is
> available via the network. Therefore, sites are encouraged to use the
> packet filtering tips below in addition to applying the patches
> supplied in MS03-026.
> Filter network traffic
> Sites are encouraged to block network access to the RPC service at
> network borders. This can minimize the potential of denial-of-service
> attacks originating from outside the perimeter. The specific services
> that should be blocked include
> * 135/TCP
> * 135/UDP
> * 139/TCP
> * 139/UDP
> * 445/TCP
> * 445/UDP
> If access cannot be blocked for all external hosts, the CERT/CC
> recommends limiting access to only those hosts that require it for
> normal operation. As a general rule, the CERT/CC recommends filtering
> all types of network traffic that are not required for normal
> operation.
> Because current exploits for VU#568148 create a backdoor, which is in
> some cases 4444/TCP, blocking inbound TCP sessions to ports on which
> no legitimate services are provided may limit intruder access to
> compromised hosts.
> Recovering from a system compromise
> If you believe a system under your administrative control has been
> compromised, please follow the steps outlined in
> Steps for Recovering from a UNIX or NT System Compromise
> Reporting
> The CERT/CC is tracking activity related to exploitation of the first
> vulnerability (VU#568148) as CERT#27479 and the second vulnerability
> (VU#326746) as CERT#24523. Relevant artifacts or activity can be sent
> to [email protected] with the appropriate CERT# in the subject line.
> Appendix A. Vendor Information
> This appendix contains information provided by vendors. When vendors
> report new information, this section is updated and the changes are
> noted in the revision history. If a vendor is not listed below, we
> have not received their comments.
> Microsoft
> Please see Microsoft Security Bulletin MS03-026.
> Appendix B. References
> * CERT/CC Vulnerability Note VU#561284 -
> http://www.kb.cert.org/vuls/id/561284
> * CERT/CC Vulnerability Note VU#326746 -
> http://www.kb.cert.org/vuls/id/326746
> * Microsoft Security Bulletin MS03-026 -
> http://microsoft.com/technet/securi...in/MS03-026.asp
> * Microsoft Knowledge Base article 823980 -
> http://support.microsoft.com?kbid=823980
XP Patch
> RPC Interface
> Last revised: -
> Source: CERT/CC
> Systems Affected
> Overview
> I. Description
> II. Impact
> service condition.
> III. Solutions
> Apply patches
> * 135/TCP
> * 135/UDP
> * 139/TCP
> * 139/UDP
> * 445/TCP
> * 445/UDP
> operation.
> compromised hosts.
> Reporting
> Microsoft
