turbodog
Looking at a streamlight twin task, not sure which one yet. I want to run it on nimh cells (I have a lot of 8k mAh cells around), but know that will reduce primary bulbs brightness/etc. Is there a replacement bulb that is rated for less voltage with the same watt output as the original?
