yowzer
I keep hearing good things about Jetbeam lights here, but they're either too expensive for my budget right now, or have UIs I don't like (User-programmable output settings? Nifty! Reverse clicky and soft pressing through them? Not so much. The Jet-III M would be ideal if it was like the Quark Tactical UI where both output modes can be programmed.) I finally splurged and got a RRT-0 and it showed up today.
While I prefer neutral tints and when a light is offered in both NW and cool, I usually get the neutral version, I realized that I didn't have any XP-G powered lights yet... so I went with the new R5 one. It's also my first light with a control ring UI. The RRT-0 was attractive because it has a nice set of outputs for general use and more oomph when needed, and no useless (To me) strobe modes or the like.
The battery versatility -- CR123, RCR123, AA, 14500 -- was also a big selling point. It's got an eneloop in it now; not sure what I'll end up using.... li-ion, but I'm not sure what size yet. Without the AA extension tube, it's still longer than I like for EDC carry in my pants pocket, and I don't like holsters on my belt (Same problem as the Surefire E1 lights have for me). So it'll go in a backpack or jacket pocket either way.
I haven't had it long enough to really put it through its paces, but I have a feeling it's going to bump the Eagletac P100A2 that I currently use at work as a thrower, since it's smaller and brighter. Well built, output levels seem to be as advertised. The XP-G R5 is bluer than I like, but it's tolerable when not white wall hunting. Decent beam, with a nice hotspot and usable spill. I'd prefer a brighter spill area, but it's not so dim as to be unusable for close up floody lighting. I like how it dims when the battery's running low instead of just shutting off. Overall I'm quite happy with it.
EDIT: Took it on a quick walk outside. Doesn't throw as well as I figured it would from the deep reflector (XP-G effect?), but my concerns about the spill brightness were completely unfounded in that setting. Plenty of spill.
EDIT: 5 levels of output but only 4 positions on the control ring? How hard would it have been to add a 5th spot? :thinking:
