If you wanted to pass batteries through the tail of the E body, the tail switch would end up being the same OD as a P6 or "classic" tail switch. As far as that little lip goes, the ground path is completed when the male plug of the switch contacts the lip. The plug is isolated from contacting the battery tube by the O-ring around it. You achieve Lock Out when the switch is backed out to the extent that depressing the switch does not force the plug in far enough to contact the lip.
I guess my aswer to the question is that yes, the little lip does serve a function. /ubbthreads/images/graemlins/grin.gif
I believe a close inspection and consideration for geometries involved as well as required will show that the switch is what it is and wouldn't work if changes were made to the existing design. The Z57 Clickie does not rely on the lip but again, to allow for battery passage, it is likely that the tube tail would require a female thread and the switch a male thread to try to keep the overall diameter of the tail switch down. Possibly doable but as Al has stated, likely never part of the design criteria for the E series. IF SF wants an E3E or E4e, they can make it in a single tube; right GloBug? /ubbthreads/images/graemlins/grin.gif
- Don
