I am a little confused about the TLE-6EX and the 6EXB.
Terralux state that the 6EX is for 4, 5 & 6 cells, and the 6EXB is for 2 & 3 cells.
Various web sites I have looked at show one as a small push-in flanged- globe looking unit, and the other as the same thing with a large slug around it (heatsink??) but the pictures are inconsistent as to which one is which.:shrug:
I want to replace the incandescent globe in a 6 volt (lantern battery) torch with a LED unit, and it appears that the TLE-6?? without the slug would fit in fairly easily. (The TLE-1F is exact match for the torch, but way too dull)
I need to know if the TLE 6??? without the slug is the higher voltage one,:twothumbs and if not, what size resistor could I use with the lower voltage LED and the 6 volt cell?
Thanks.
Thanks.
