Re: ifei nitecore only 1/2 hour run time ????
Well, AFAIK, most "3.0v" Li-ion (LiFePO4 excluded) batteries are actually 3.6v Li-ion's with a small pcb that drops the cell voltage at the terminals.
This process wastes energy, so while a "3.0v" Li-ion may state the same capacity as a regular 3.6v Li-ion cell, it will not have the same capacity.
Even 3.6v Li-ion cells do not match the capacity of a Primary cell. Yes, technically current draw will be slightly lower at the tailcap due to the higher voltage, but it still will not have the same capacity as a regular CR123a cell. A high quality CR123 is rated at ~14-1500mAh's, as opposed to a Li-ion RCR123/16340 which generally state ~750mAh capacity, but rarely achieve >600mAh.
Start using a primary cell, and you will definitely notice increased run times.
