Re: FS: TiCN Draco(SOLD), 3,000+ Lumen Nailbender Custom Triple SST-90 Mag Monster
Sent paypal as gift please let me know if you received it. THANKS.
Got it! Draco is
and will go into the mail tomorrow.
what is the number of levels of the mag mod and their respective runtimes?
King: The mag uses the programmable d2Flex driver (v2) which lets you choose between 3 different user interfaces. The first UI (called Fixed) provides 8 brightness levels, the second UI (called Portable) provides 5 levels and the third (called Bicycle) is optimized for a bike light and provides various fixed and strobe options (2, 3 and 5 levels). I have the light currently programmed to the Fixed UI, which I find useful because it allows instant on to the lowest level (level 1) by pressing and holding the switch and the ability to switch quickly to the highest level (level 8) without scrolling through all the levels. This driver is pretty remarkable in its versatility and features - in addition to the UI choices, the driver includes a Force Level feature (initial on level can be set), SuperLock (lockout mode to prevent accidental turn on), Thermal Protection, Auto Sleep and other features. Details regarding the d2Flex and an instruction manual can be found
here.
I have no idea of the runtimes for each of the various levels. I think the runtime on level 8 will be limited more by the heat generated than the capacity of the cells. I can tell you that I generously use the highest level when I run the light, and I think I've only charged the cells maybe twice in the 3 months I've had it.
Hope that helps.
