Michael also use the cheap DX meter for the DEFT & up adjust with a correction factor. That made me decide to get the DX metter, as I am benchmarking DEFT numbers for my Aspheric mods.
https://www.candlepowerforums.com/posts/3348264&postcount=12
I have a cheap DX meter so have had to improvise. When I take 5 meter measurements of my Raidfire Spear and calculate back I get a little bit more than 16K lux. From everything I have seen here that is absurdly low and there are other reports of the DX meter reading excessively low. The lux reports I have seen seem to be in agreement that it puts out around 24K lux. I even modded mine with an R2 WH so it should be ever so slightly brighter. So my rather unscientific way of getting measurements is to use my Spear as a "calibrator". I set up the meter and then backed off until I got a reading of 22lux(about 26'). I did 22 instead of 24 as I wanted a little conservative budge. So I test all my lights at the exact distance I got 22 from the Spear. The first DEFT-HO of this run gave me a reading of 180 using this method.
My understanding is that Michael moves his light closer until the Spear flashlight readout out goes from 16K lux to 22K lux, that's an increase of 37.5%. Unless my interpretation is in correct, I think that might be a bit over adjusting. From various other posts I read, most people compared DX meter to good meters reported 15% to 20% difference.
I am using the more modest adjustments, for example on my MagDragon Jr., I got 139,000 lux @ 1 meter real measurements (Measure 10 meter lux & convert to 1 meter), then I up adjust slightly & estimate my lux to be around ~150,000 (~8% up adjusted). I want to be conservative, so my numbers can back me up in case one day the MagDragon Jr. run into a DEFT FTP & duke it out
On my MagDEFT, I measured 100Klux & estimated real lux to be >115K lux, that was a 15% up adjustment.
Overall, I think get a DX cheap meter & do 10-15% up adjustment is a pretty good alternative vs. buying an expensive meter.
