Just wondering whether one of my e01's has been damaged, or if it just has a fault.
I gave my son an e01, and it is now definitely significantly less bright compared to another e01 I have thats around the same age. I've given it a clean, swapped batteries, and swapped bodies with the one that is brighter and no difference.
The reason I'm wondering if it has been damaged is a few times he's fallen asleep with it turned on and I've only turned it off a few hours later, meanwhile its been clutched in his hot little hand under the covers so its pretty hot.
The other thing is at one point he took the battery out and put it in the wrong way, he was then trying (and failing) to thread the head back on - he never got it threaded to get it on, so the contacts on the outside edge of the head never touched the non-anodised ring on the body. But could this have still caused damaged? I don't think there was ever a reverse circuit, but all the points on the bottom of the head (which is flat) would have been touching the flat base of the battery. But that isn't a circuit, right? If you did manage to get the head on with the battery reversed, would you simply totally destroy the led, or would it reduce the brightness like it is?
Or is it faulty?
Or is it faulty?
