bondr006
Well, I have had this light for a week and I really like it quite a bit. The UI is the same IBS UI that the JET-l Pro has. That being three user definable levels anywhere from 2 lumen up to 135 lumen.....with the option to set any of the levels as strobe, beacon, or sos. It takes an AA battery. I am using a NiMH in mine, but I tried a 14500 and it handled it well with quite a bit higher output. It does get pretty warm with the 14500 with extended use on high, but takes awhile to get uncomfortably hot. I also like the form factor quite a bit. It is much slimmer and quite a bit shorter than the JET-1 PRO, so it sits in the bottom of a pocket quite comfortably. It has a really nice camouflage HA3 finish with just the right amount of knurling covering the surface for a good grip. It has a reverse clicky that allows the changing of the levels by half presses while the light is on. The emitter is an XPG R4 which gives it a nice broad hot spot with great spill which makes this a nice EDC light. I would recommend this light to those that like to carry a light in the pocket. It is easy to use, and just feels really nice in the hand. Did I mention that I really like this light?
Below are the manufacturers specs, and a whole bunch of pictures I took for your viewing pleasure. I will get some comparison beam shots up soon. In the mean time enjoy, and be sure to let me know if you have any questions.
Manufacturers Specs:
Features:
One AA battery
Max output: 135 lumens, 65 mins
Min output: 2 lumens, 50 hours
Lots of pictures.....Enjoy!
BK135A and JET-l PRO
Beam Profile High
Beam Profile Low
High
Low
Features:
- LED: Cree XP-G R4 bin
- Max output: 135 lumens
- Reflector: Aluminum OP reflector
- Lens: Coated mineral glass
- Finish: HA III Military grade hard anodized
- Battery Type: one AA battery
- Waterproof: Meets IPX8 waterproof standards
- Features JETBeam's I.B.S. user programmable circuit and allows the three user-defined modes to be customized to any brightness level.
- Stainless steel rings to protect circuit and thread
- Reverse polarity protection function
- Tail stand feature
- Size: diameter 17mm, length 90mm
- Weight: 27g (not including battery)
One AA battery
Beam Profile High
Beam Profile Low
High
Low
