Beastmaster
Been a while since I've been on. I came across a Streamlight PT1L and I ended up getting it because of it's killer price.
Since it's a single 123a sized EDC light, I figured I'd throw up a quickie review and some comparisons with my Novatac 120p and Surefire Backup.
Background: the SL PT1L is a black anodized aluminum bodied flashlight that has a C4 LED and is rated at 110/12 lumens high/low and has a strobe function. It comes in a blister pack with a tiny holster, a 123a Energizer battery, a belt clip, and the light.
Some quick findings:
1) it's thinner and lighter than the Novatac. It's still big enough to fit my hands.
2) the reflector is deeper, giving it a good throw. The reflector is a bit 'ringy' where you get a central spot, then a shadow ring of sorts, then some spill.
3) the UI is interesting. You have momentary on, full on, then strobe, then low. I like it.
4) strobe is as fast as my Novatac.
5) it takes normal 123a, 3.0, and 3.7 rechargeable 123's as well. Regulated and unregulated batteries fit fine with room to spare.
6) unscientific testing with my Meterman LM 631 shows the output of the light is about 30% brighter with a 3.7v rechargeable. I packed away my light box, so I have no real way of testing it out in a more controlled situation until I unpack it out of my garage. Testing was done using a 48" long painter pole with the probe on one end and the light on the other.
7) 3.7v batteries screw with the UI. I can go from high to strobe easily. Going from strobe to low was far harder. Throw a normal one in and the UI works fine. I have another PT1L still in it's blister pack, so I'll test it out to see if I get the same results.
8) the light is sort of tail stand able. It will wobble a tad. The bezel in the front is really a minor scalloping.
I've been carrying this light in place of my well worn Novatac 120p for 2 weeks now. It's just as useful, far brighter (when using 3.7v rechargeable), and it still fits the hand well. Compared to the Surefire Backup? No comparison. The SL PT1L is far better.
For the money, and if you use or have rechargeable 123a batteries, this light is well worth it. It's going to take the place of my Novatac as my EDC light.
-Steve
-Steve
