ValeTudoGuy
- Joined
- Nov 7, 2008
- Messages
- 35
Hello :wave: I have been lurking here for a while. I first found this place after buying an LED Lenser Police Tech Focus and doing a search on the net to find out a bit more about it, I ended up ordering a Fenix TK11 off the back of reviews here before I even logged off! That was around 8 months ago and I now own 13 flashlights. The TK11 changed the way I look at flashlights and I am finding myself becoming increasingly obsessed and indeed recently I find my thoughts often drifting to thinking about torches and building my own
My first attempt was a polished balti dish drilled out to accept a 100w H7 car headlight bulb connected to a 12v Lead acid battery I had spare. Its quite bright although I want to go much brighter! :twothumbs
Anyway to the point..... Recently the Traffic lights at the bottom of my road were being re-furbished. I got talking to the workmen and ended up walking away with two reflectors, one from behind the green light which is a roughly
12" parabola with an "orange peel effect". The other from behind the arrow signal is around 15" wide and is a highly polished bowl.
They are both metal and have what I believe is a GY6.35 bulb fitting in the center.
I also got 6 bulbs which are marked as 50w 12v "M32",
My question is. Is there much I could do with these?
I have visions of huge beam cannons. :laughing:
I was wondering if there was a bulb that would fit directly into the current fitting that would give me what i'm after as I would rather keep them intact, I did a bit of research and found some Sylvania 64625 100w M32's which appear to be projector lamps that may or may not be of use?
If not then I would be happy to drill them out to fit whatever is going to give a total wow factor!!!!
I'm sure that you guys will have some fantastic ideas, so thanks in advance for any help.
ValeTudoGuy
ValeTudoGuy
