geepondy
I believe it has been posted that you could put just 4 AA lithium batteries (as opposed to 8) in a PT Surge and it should be OK as the higher voltage should be compromised as you don't have another battery set in parallel. Well I tried it and the light bulb blew instantly after a split second of intense light.
I wish someone could come up with a suitable Surge bulb that worked with NIMH rechargeables. When I use my Surge with NIMH's, the light output is steady but noticeably dimmer then with fresh alkalines. When I use alkalines, the initial brightness is good but dims steadily throughout the battery drain.
