The problem:
Currently have the MC-E wired in parallel, 3.7v one LIon, ~2.8a from a 8x7135 from Kaidomain. Great right? Started to notice flickering and one die putting out much more light than the others. No good. I am assumming one die is eating up all the power while the rest suffer.
Proposed Solution:
Change the 8x7135 driver. Re-wire it to run 2x7135's to each die by 4 separate circuits. 2x7135s should put out my required 3.7v and 700ma required to run each die seperately.
If I can do the soldering, can you see any error in my solution? Any comments? Has this been done before??
Proposed Solution:
