This Light could have given the Jetbeam RRT-3 a run for its money. To bad it only puts out 800 Lumen, unlike the 1200 lumen Jetbeam Raptor.
Features M60R
● Luminus SST-50 LED, with a lifetime of 50,000 hours;
● Three levels of constant output, one strobe mode
Three modes constant output: 800 Lumens (1hrs) - 180 Lumens (4 hrs) - 13 Lumens (28 hrs)
Strobe mode: 800 Lumens
● Digital Sensor Magnetic Control system, slightly twist the Rotator Ring to select from different modes
● Constant current circuit, constant output
● Effective range of 300 meters
● Using 6*CR123A batteries (this light can be activated by using 2 or 4 CR123A batteries as well, same output and shorter runtime)
● Working voltage: 4.5~9V
● Reflector of good quality maintains both great throw distance and spread, perfect beam pattern
● Dimension: 161.8 mm (length) x 57 mm (head diameter) x 40 mm (body diameter)
● Weight: 240g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III hard anodized
● Waterproof accords with IPX-8 standard
● Ultra-clear toughened glass lens resists scratches and impacts
● Tail stand and can be used as a candle
● Accessories: lanyard, O-ring
http://www.sunwayman.com/html/products/201008/36.html
Model: RRT3 Features:
LED source: Luminus SST50
Max output:1200 lumens(LED lumens)
Reflector:58mm-diameter aluminum reflector
Lens:Toughened ultra-clear mineral glass with anti-reflective coating
Material:T6061 T6 aircraft aluminum alloy
Finish:HA III Military grade hard annodized
Battery Type:CR123×6,18650 Li-ion×3
Voltage: 6.5-18V
Switch:Forward clicky
Waterproof:IPX-8 standard waterproof
Measurements:Head diameter 63mm
Tube diameter 46mm
Total length 198mm
Weight:530g
Patented Product
Output & Runtime:
1200 Lumens, 80 min
850 Lumens, 120 min
550 Lumens, 180 min
470 Lumens, 230 min
300 Lumens, 350 min
150 Lumens, 620 min
1 Lumens, 250 hours
Strobe: 1200 Lumens, 160 min
