Li-ion packs are lusualy listed as multiples of their single cell nominal voltage of 3.7. Max capacity is 4.2 volt. Some longevity is gained by undercharging. Seven cells at 4.2 volt would be 29.4 in series, less than the maximum for the buckpuck. Good there. As long as the fully charged pack is less thatn the 36v maximum for the puck.
If the puck is rated to drive into the Vf load of 3 MC-E's (3 x 3.4 @ 700 mA) = 10.2 Vf total, all three will be driven at 700 mA all the time until the battery's low voltage cutoff (I assume it has one as well as a max voltage out/short protection).
The highest output bin is a bright white and will give about 470 lumens at 350 mA x 1.7 (factor from current versus poutput chart)= almost 800 lumnes under controlled laboratory conditions. you will run them hotter (losses 10-30% or more if they get really hot) plus a 10-20% lens/reflector loss. Say 25% overall as a bit on the high side if you don't get silicon smeared on the lens cover, for about 600 lumens each out the front, or 1800 total.
You may wish to consider lower output but warmer colors in the side beams. I think you might like levels, but don't know if your selected buck puck will take a variable resistor to accomplish that. If you shut the light off I suppose you could run switch them from series to parralel with wiring and switch to accomplish that and reduce the current to 700/3 = 233 mA for about 70% of the 350 mA output, or 70/170 = 41% of max ouput.
I suspect the buckpuck won't tolerate a no-load situation without failure and a power pulse to the LEDs would be bad, so the changeover would from series to parallel or reverse would have to be with battery disconnected.
Look through older design threads when buckpucks were cutting edge. The topics by category sticky thread at the top may help.
This is NOT a good road light BTW.
