I have been using the new dropins I got from Nailbender for about a week now. I got a sst-50 and mc-e p60.
Both are very high quality
I noticed that the mc-e does not loose as much output as the sst-50 does over time. It seems like it can hold the brightness for longer. I think the sst-50 does has a slight higher turn on, but after about 30 seconds its clear that the mc-e is the brighter one. Its as if it is less effected by the losses associated with heat.
And with the Op reflector, I barely notice the black spot in the center...
Are these results similar to what others have found?
