Sold/Expired SPF: PAR36 4.5" Stainless Steel Turn Key hot wire with 4509Q ~130W.
ma_sha1
CT, USA
SOLD: PAR36 4.5" Stainless Steel Turn Key hot wire with 4509Q ~130W.
I am usually a LED guy, This light was inspired by the FM PAR36 head:
https://www.candlepowerforums.com/threads/273839
Light FS is a complete Turn Key PAR36 Sealed Beam package.
The only thing you need to supply is 4xAW IMR 26500 batteries.
  • Vintage Stainless Steel flashlight with 4.5" PAR36 Head.(Not FM head, the Host came with a 4.5" PAR36 head)
  • Completely re-built switch & contact mechanism
  • Installed a section of Mag D tube that has been machined down to fit inside the vintage tube to host the Switch from Mag D.
  • Mag D switch with resistance mod, copper contact for battery
  • 18AWG Teflon Copper wires to hook up the lamp
  • PVC battery sleeve for 4xAW IMR 26500
  • 4509Q quartz halogen PAR36 Aircraft 100w landing bump included
  • Driven to 16.6v ~8Amp, I.E. ~130W.
For a Vintage light, it is in super excellent shape, because it's made out of stainless steel.
For beam shot vs. Mag 1185 on FM deep reflector, see Luxluthor's testing here:
https://www.candlepowerforums.com/threads/205987&page=2
Asking $169. Turnkey with lamp, battery not included.
USA only. Two PP/shipping options:
Shipping & Insurance using PP gift option: $15 or
Ship, Insurance/PP fee using PP goods: $22
Size comparasion to Mag 2D.
Front view of the lamp, which is brand new.
The opposite side of the Mag switch, I left the stock switch alone.
It doesn't function, just a decorative piece to retain the vintage look.
YAK-28
akron, ohio
Re: PAR36 4.5" Stainless Steel Turn Key hot wire with 4509Q ~130W.
nice, how does it compare to your franken magdaddy? does the thinner host body heat up much when run or does most of the heat stay towards the bulb?
ma_sha1
CT, USA
Hi, This light has more Lumens 130W vs MagDaddy ~105W.
The MagDaddy will still throw further because it's much bigger lamp diameter almost 6".
The heat is concentrated at the bulb & head, does not go down to the tube much.
ma_sha1
CT, USA
The stock light tail cap says HPICO, MADE IN USA.
That's all I know about it. Don't know model # or how old etc.
ma_sha1
CT, USA
Donn, I am sure you are right about this, spelling is not my strength :eek:
