I own both the M20 R2 Premium and the M20 R5 Special Ops. I love the M20 R2 and decided to try the R5 version due to the slightly added lumens. I have a need for two of these type lights and was close to buying a second M20 R2 when the new R5 was introduced, so I figured what the heck. I have to tell you that I am disappointed in the R5 version. I like the UI better but it is not really all that much brighter and it doesn't throw as well either. Sure it has a nice wide beam and lights up a bit more area than the R2 but I was hoping for an "upgraded R2" with equal to or further throw plus being noticeably brighter. It's fine for what I am using it for but I find myself now wanting the new M31 as the reviews and beamshots I have seen on it are what I am looking for in terms of brightness and throw...............
That's my take on it, wish I had waited a while longer and put the money towards the M31.....................
Terry
Terry,
Timing is sometimes everything! I was just about to place an order for the M20S when I decided to check my email and found that you had responded to this thread, as a result I have decided on the M20S. Your post helps me and I believe I may be able to help you. But before I place any order I will have a question later.
First, your post helps me because the more flood/less throw beam is what I wanted out of the M20 series and expected from the XPG-R5 w/ an OP reflector to replace my EagleTac T20C2 MKII.
Second, based on what you describe that you were hoping from the M20S, I think describes another torch I have that might fit your needs. That is if you haven't already reviewed it. It's the 4Sevens Maelstrom G5 which is just a tad bigger than the M20 with a larger, smooth reflector bezel helping throw an R5 emitter's beam. It has a more traditional bezel turning UI and is a great thrower of 17K+ lux based on selfbuilt's review and testing. Unless you really want the M31's side switch, then the G5 is half the price. Here's a couple of links of the G5 for your consideration,
1) Selfbuilt's Review:
https://www.candlepowerforums.com/threads/282390
2) Lowest price with CPF discount code
notebook:
http://www.environmentalled.com/4Sevens-Maelstrom-G5-LED-Flashlight-p1253.html
I hope this helps!
As for my question, as I stated in an earlier thread, I just learned about PWM, but need your feedback. I understand that the M20S uses PWM for current control with the side switch and as such, depending on the person who's using the M20S, it possibly creates a visible flicker at all brightness levels. The question is,
does the flicker happen when the light is held stable as in illuminating an object, or only when you move the light as when others shook it to see if it flickered?
If it doesn't flicker when stable, I can't think of a reason not to get it since the light's size and features are what I was looking for and I would prefer the side switch UI. Thanks!
John
