Just the other day I noticed the button on slot 1 stopped working. Won't do anything when I press it. My second charger of the exact same one is fine though.
Long story short, took the charger apart, even went as far as removing the metal plate that represents the clicking button did a bypass by direct contact what looks like the gold contacts (similar what you would find inside of a game controller) and nothing the display does not blink.
Put back the button (actually is nothing more than a piece of metal tin plate have to be careful of not breaking the tiny legs that holds it in place). After all that's been done, put the screws back together except leaving the back cover out. Put the battery in slot 1 pressed the button and nothing.
The only time when it semi worked pressing the button on slot 1 is when I had my fingers on the circuit board on a certain spot, but after that it stopped working.
This makes me to believe that this is not a contact issue with button, but rather a open circuit somewhere on the board leading to slot 1 button.
Overall the master 3 buttons works. As long as that's working I could careless lol.
Any second opinions. Better yet any one with a background of electronics would be nice.
Cheers.
Cheers.
