Recently when i was surfing a site, it is said that the stability of l1 lumamax
isnt reliable,regarding the flux regulation made by the tailcap.
The information is: the tailcap contain 3 very thin pieces of metal,
during half press 1 metal piece contact with the PCB and low intensity is achieved while full press, 3 thin metal contact with the PCB to give you a high intensity beam.
My question is:
1. It is said that the 3 pieces of metal is very easy to be fractured, is it true?
2. The light regulation is done by internal resistor or the metal pieces act as a signal controller(by high and low voltage?) which "tells" the IC rather to give you a high or low beam? In the other way: do the low beam extend the runtime.
I am being hesitate that should i get a L1.
Jh.
My question is:
Jh.
