Pics and/or parts list?
ROPs are great. I love my 2C Mag ROP-Lo build.
UCL lens, MOP reflector, 3854-Lo bulb, download's Mag C Tower, 2x25500 Li-Ions, and one of FM's tailcaps.
It has a beautiful beam and should run for over an hour per charge; it also seems like a lot more light than it's rated for! :twothumbs
Low is a 2 amp device. Capacity of your batteries divided by 2000 will give you theoretical runtime. Of course don't drain it that far, li-ions don't like it.
We have always heavily overdriven ROP bulbs after finding out that they could take it. You can light a low bulb HOT on 8.4V of high-rate NiMH with extremely little voltage sag, and it won't blow. I did that all the time in the early years.
In fact the original 3854 product is designed for a 6V SLA system. But on CPF it almost seems 'wrong' to drive it at 6V when we know it has so much more potential.
7.2V is our typical drive voltage, and incans put out A LOT more light when overdriven, as well as burning hotter and whiter for better color temperature and color rendition. For example, 200 (rated) bulb lumens becomes a stunning 378 when you bump the voltage. Nearly double.
When I first started the ROP project in '04, 378 lumens was pretty sick. For comparison, our best LED was the Luxeon V, 180 lumens on a good day at full blast. Most used the Luxeon III, 80 lumens.
Did he itemize the parts list? What did he want for the reflector?
I wonder if a ZR mod can be made for the Mag tailcap. Seems like it would be pretty straightforward because it doesn't function like a SF tailcap.
Yes it can be done. You simply need to find a way to bridge the negative terminal of the battery to the aluminium body shell of the light, since the switch is up front and isolates the positive terminal, breaking the circuit there. The negative terminal is always connected. This exercise can be left to the reader, for example you could machine a tailcap out of solid silver or gold for electrical conductivity and connect it to the shell, which would also boost your
BLING factor. But I am sure there are other ways which are more practical.....
