Swapping MagLED reflectors Rebel with 3W?
PCC
Sitting' on the dock o' The Bay...
If you are only changing the reflectors then, no, you cannot do it. I haven't tried replacing the reflector and the switch assembly between the two, though, so I don't know for a fact if it will work. The switch hole sits further forward on the Rebel Mag body tubes (I think) so they may have changed the relationship between the switch and the head.
Chodes
Australia
The rebel reflector will not fit in the Mag C head anyway. You'd need to remove some metal from the shelf inside the Mag C head.
alpg88
can new rebel reflectors be bought separately, anywhere????
