march.brown
I have decided that I need my ITP A1 to tailstand and have a magnet attatched so I had a look on a certain ?bay site.
I found some ring magnets that will do the job perfectly ... It is my intention to Araldite one to the tail-end of the torch ... The magnets are 20mm across with a 10mm hole and are 3mm thick ... Since the lanyard attatchment post on the torch sticks out by 3mm and is 5mm across , it should easily go through the 10mm hole in the 3mm thick magnet ... This would still leave room for a thin lanyard to be threaded through the hole in the post if required.
I had five magnets for $5-50 including postage , so it's not an expensive modification ... The only snag is that the torch is black and the magnets are nickel plated ... Still , it should be OK as a user.
To find them , I looked for "Neodymium ring magnets" on that site ... There are other sizes and thicknesses of magnets but these seemed to be the ones to fit the ITP A1 ... The A1 can still retain it's pocket clip , so I will be able to carry the torch and a magnet together in one piece ... Since the lanyard attatchment post will not be sticking out from the magnet , the torch will tailstand easily.
It's just a matter of waiting for the magnets to eventually arrive from Korea.
