Beautiful job!
Might i respectfully suggest something?
A more concentrated solution (drano granules work well) or a longer bath.
No sanding should be necessary, if the finish stops coming off, add more naoh.
The problem with sanding is that anodizing is very hard, sanding it off with abrasive paper that is also aluminum oxide will be very labor intensive and possibly counter productive, as the areas that were already stripped will be considerably softer than the parts that still have the hard anodized coating, meaning that the abrasive will skid off the anodized parts and gouge into the soft bare aluminum.
The method I use is very strong naoh in the form of drano granules, let the part sit for 5mins, take it out and scrub it with a scothbrite pad.
If anodize remains, i re dunk the part for a minute or two and then scrub again until it's all off.
As long as i ensure that the art is suspended so that it can't come into contact with any undissolved granuals, i get no pitting whatsoever, just a nice even finish similar to sandblasting.
Hope this saves you some time and elbow grease on your next project
