What makes you think that such patent can only refer to the mounting mechanism and not to the whole concept of dual use of a portable (flashlight look alike) superlight, also as a vehicle or mounted searchlight or other mounts and quick disconnect base ?
Regarding your time table for patents approval: The process may take more then 4 years since you first file and register the application which grants you 1 year before the application process takes place and only then you may or may not file for the patent which depends on changes which may or may not required in the various claims within the application.
only after this process that may take more the 3-4 years you may or may not be granted with the patent.
Considering the fact that the actual legal date of validity for the patent is the date in which you have filed the first application i.e sometimes 4 years prior to the actual grant of patent, requires from you to look at the industry 4-5 years ago and not of today's products.
Have you ever seen, prior to the CSWL project, or for that matter 4-5 years ago, any HID or short arc xenon, portable flashlight mounted on to anything? Or specifically a mounting base which enables the user to use it both as a flashlight and as a mounted searchlight? I wonder.
At that time to best of my recollection, (and collection What makes you think that such patent can only refer to the mounting mechanism and not to the whole concept of dual use of a portable (flashlight look alike) superlight, also as a vehicle or mounted searchlight or other mounts and quick disconnect base ?
) the only players in the superlight markets where Peakbeam, Xenonics, Shonan Japan, Reva int'l, German Trebelight (Kenrad in USA) and a first version of 50w short arc Kumkang Korea (the current producer of the Polarions).
None of which was offering such an option.
