SilverFox
We had a little informal gathering last week and were hoping to compare the SureFire 10X with the Mag Charger, the TigerLight, and the Ultra Stinger. The guy with the Ultra Stinger was unable to make it. The setting was a local park with little ambient lighting.
The 10X lived up to it's name. It Dominated all the lights by throwing a wall of light that was very bright. 500 lumens is a lot of light. This light reminds me of turning on the headlights on my truck. Just a nice even bright beam. Those of you that do not have a 10X can kind of see what it is like by covering up one of you headlights and turning them on.
The Mag Charger can be focused to a tight spot. That spot can be seen within the 10X beam. The TigerLight (with Generation 3 lamp) does not focus, but the hot spot of the beam could also be seen in the 10X beam. If you open up the focus of the Mag Charger, the 10X just wipes it out. The same is true with the spill light from the edges of the TigerLight. We pulled out a (2 million candlepower?) spot light and the spot beam could also be seen within the beam of the 10X, of course there is little spill light from a spot light.
A question has come up. The 10X puts out more light than both the Mag Charger and the TigerLight. Why can we see the hot spot inside the 10X beam?
I checked the 10X and TigerLight on my light meter and noticed the following:
10X at 1 foot = 5500 foot candles
TigerLight at 1 foot = 4500 foot candles
Both lights together at 1 foot = 6500 foot candles
I was expecting close to 10000 foot candles. What happened to the other 3500 foot candles?
If light is additive, the meter should have read closer to 10000 foot candles, If light is not additive, I should not be able to see the hot spot of the TigerLight in the beam of the 10X.
What is going on here?
Tom
Tom
