[ QUOTE ]
raggie33 said:
when ya say lens i assume ya mean the glass part?not the cone thing?
[/ QUOTE ]
I'm pretty sure you take the transparent plastic thing out of the flashlight, not the cone-shaped thing.
I don't know where my Rebel is at the moment, so I can't be any more specific. /ubbthreads/images/graemlins/frown.gif
(Edit - a little while later)... Found my Rebel.
Unscrew and remove the bezel. The part you want out is a clear plastic lens. Tip the flashlight upside down in your hand, and this lens should fall off the flashlight body and into your hand. If it doesn't, you can use a fingernail to nudge it out. Screw the bezel back on.
The Rebel will not have any weather or water resistance when you do this, so please try not to get it wet or use it in the rain. The reflector will also be vulnerable to getting lint and other garbage on it, because like the LED, it will be exposed.
