Given an MN-10 Bulb
C
claychps
Guest
Hi all,
A co-worker gave me an SF MN-10 bulb for free along with 12 CR123 Panasonic batts. His brother is in the service. I want to do something with it but am not that experienced. Any suggestions would be appreciated!
__X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :)
__X__Less than $100.
3) Format:
__X__I want a flashlight.
4) Flashlight-specific format/size:
__X__Every day carry medium (4-7 inches).
5) Emitter/Light source:
__X__Incandescent (known for superior color rendition)
6) Manufacturer:
__X__I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
7) What battery type do you want to use?
__X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
__X__50-150 yards/meters (I live in a very rural area/farm with wide open spaces.
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
__X__90-120 minutes (Runtime is moderately important, but still not critical)
__X__Slightly Important (Walks around the neighborhood).
12) Switch Type and location
__X__I want a tail mounted switch
__X__A simple on-off with only one output level is fine for me.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today
Thanks,
Robert
