Z
z_Luckdog
Guest
Hi all. First post, but I've been lurking for a while. I need to replace my stolen TK-11. I was very pleased with it's performance and quality construction, except that the anti-roll part wore through the holster, so then it ended up in my pocket, then on my desk, then in someone else's pocket, then never to be seen again.
So, now I need to replace it and would like your input.
I would like to stick with the 1x18650 format, and need to have a belt clip or quality holster.
I will be using it primarily at work, where I will be standing in daylight, looking into a dark, 100+ yard tunnel - so I need good throw, with little spill.
Multiple modes are not important, as long as it has hi and normal. Anything else is just gravy.
The light will be exposed to fine dust, and occasionally very high heat (400F).
Needs to be small enough to carry at all times, and, of course, it needs to be ridiculously bright. I'm not concerned with runtime.
Would like to stay under $150, but am interested in money is no object suggestions as well.
Thanks in advance! Any and all suggestions are appreciated.
