Jumpmaster
Hi, Folks...
I just bought a Surefire Aviator (blue LED) a few days ago and while I'm generally very impressed with the quality of construction, I noticed that mine produces very, VERY bad dark rings when using the LED mode. The incandescent light is fine, but the beam from the LED's is terrible...not at all what I would expect from Surefire.
Is this a common issue? Have other Aviator owners noticed this also? The odd thing is you would think if it's going to have rings like that that it would have three since there are three LED's...mine has two rings. When looking at the reflection off of a surface with the light about 2" away, you can see all three LED's lit, but two are very obviously closer to each other than to the third one. Farther away, those two that are closest to each other merge and form one of the interlocking circles of those two dark rings I mentioned earlier).
Anyway, if this has been discussed here before, my apologies. I searched here on cpf and elsewhere for information on this before posting. I can try and post a beam shot or two if it would help...I'm not sure if my description made any sense... /ubbthreads/images/graemlins/confused.gif
JM-99
JM-99
