MY
I was showing a friend of mine in Alaska some of my LED lights (gave him a LGI which surprised him with the brightness – I think that he has only seen 5mm LEDs and not any Luxeons) and asked him what type of light he uses for the Iditarod race. Not surprisingly, he does not use a LED system since he thinks they do not produce enough throw during whiteout blizzard conditions. He (like most mushers) uses a Petzl halogen head lamp (don't know what model) with extra lithium batteries. The problem with the Petzl is that it eats batteries and the bulbs blow quite frequently. Plus it is not bright enough to blast through blizzards although during most non-blizzard times, it is adequately bright. At rest stops and layover chores such as feeding the dogs, his lumen needs are substantially reduced. Mushers go on a four-hour running schedule between breaks so it is imperative that a reliable light is carried.
I suggested using a NiteRider HID light with a headstrap but I think that there is still the durability problem and the output is not flexible when he doesn't need the lumens. I thought you CPFers could come up with a good LED based alternative. My friend indicated that there would literally be thousands of mushers who would gladly pay top dollar for the ideal LED light.
Here are his requirements:
Headlamp design
Run time of 8 hours
Extremely bright for whiteouts but possibly dimmable
Prefer spot beam with some side spill
Lithium battery pack carried in jacket
Extremely dependable and rugged
Waterproof although it probably should read weatherproof
Must operate at below zero temps for many nights
Musher must be able to handle light with heavy mittens (thus any changes must be done by feel)
There are probably other requirements that I have forgotten.
Please help with suggestions. If anyone is serious in actually making such a light, I can put you in contact with my friend.
Thanks in advance.
/ubbthreads/images/graemlins/help.gif /ubbthreads/images/graemlins/help.gif /ubbthreads/images/graemlins/help.gif
Headlamp design
Run time of 8 hours
Thanks in advance.
