Overclocker
We know that the LD20 uses the same head as the 1xAA LD10.
The LD10 drains a cell to below 1.0V, probably 0.8V? i dunno
Now if you feed the LD20 with 2 slightly unbalanced NIMHs the LD20 will drain the stack (in series) down to 1.0V or under.
Will the weaker cell become reverse charged?
Is this a problem in actual use?
