I'm about to make a 5W light that I'd like to power off 5 rechargeable Sub C/D NiMH cells. My limited understanding is that this will give me an initial 7 volts, rapidly decreasing to and stabilizing at 6 volts until near depletion.
I do not want an initial brightness that quickly decreases. I want truly regulated brightness/current.
I would prefer it if the regulator "shuts down" after the batteries are nearly depleted to protect them. Outputs for a small (red) LED that indicates falling out of regulation would be highly desirable.
I'd like to slightly overdrive the 5W. I've considered some available possibilities, but nothing seems a perfect match to my requirements.
Please suggest some options. Work on custom electronics could be compensated. Thank you.
