89.5 hours...I can still navigate a small room, but wouldn't want to use it out of the house, except for looking for something in a pack, etc.. Now it's pretty much limited to a "Real stealth light" (pitch black/moonlight, need to check a map real quick, etc.), a comfort light for kiddo's, or for reading. Great for use on a plane when a white light may disturb other passengers.
There was another significant drop around the 70-75 hour mark (or so it appeared). While not ideal, it is still providing usable light. if some one could do a "real runtime test" on a 5th Gen white head, it would be neat to compare the two side by side. You need less white light to be usable...if this was white and putting out the same lumens, I could still see it being used as a navigation light, the only advantage to red being 1) Stealth, 2) Night Vision Preservation, and 3) The extended runtime (how much remains to be seen) that is inherent of Red emitters.
Again, I'll put this in a thread of it's own so others who may be interested will be able to more easily find it.
