LightChucker
Don't take it apart - just twist the big battery spring until the parts automatically align themselves from the outside.
My L4 switch worked perfectly from the factory, but curiosity "forced" me to take it apart just to see how it worked. Of course, it didn't work so well when I put it back together. After several attempts at reassembling it, I just twisted the big battery spring. I could feel the parts align, and I could hear a faint snap as everything came together correctly inside. That is all I did.
The thing that caused me to consider such a simple solution was that I figured the time it would take to assemble such a delicate device, with several small, loose fitting parts, would be prohibitive. So, there had to be a technique whereby someone could quickly throw the parts together as fast as they could, and then do something externally to align everything. The big battery spring is the only thing that you can access from the outside after everything is assembled.
I figure that the same people that left out the gaskets also didn't know the final alignment step to assemble the switch. Oh well, this is a simple thing that anyone can do without special tools. It worked for me.
Please let me know if this works for you.
Hope this helps someone!
Chuck /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/wink2.gif /ubbthreads/images/graemlins/thumbsup.gif
